• You're one step from joining Laser Cutting Forum – Fiber & CO2 Machines, DIY & Industrial Uses.
    Create a free account to post, follow threads, and never miss an update.  Sign up free →
Epilog Fusion Edge 24 wavelength or beam diameter?
p3rcyjnsn
New member
Joined
Aug 4, 2025
Messages
2
I'm working on a project using the Epilog Fusion Edge 24 and I'm trying to figure out how much material the laser removes when it cuts. I'm cutting some small, intricate parts out of 1/8" basswood plywood.
I've been doing my own research and read that the specs for the laser say it's a "50 or 60 watt... 10.6 micrometers" source, but I'm not sure if that 10.6 micrometers refer to the actual diameter of the laser beam, or is it the wavelength? If it's the wavelength, what would be the best way to figure out the actual beam diameter or kerf for this machine? I'm trying to get my design dimensions as precise as possible. I'd appreciate any insights!
I just wanted to clarify something I found out. That 10.6 micrometers number? It actually refers to the laser's wavelength, not the width of the beam. When you're using a Fusion Edge to cut through 1/8" basswood, the kerf usually falls somewhere between 0.004" and 0.008". But honestly, the best way to really dial it in is to try out a few test cuts.
Back
Top
